964 Forum 1989-1994
Trickle charger connection
Old 03-05-2013, 03:05 PM
james_marshall
james_marshall's Avatar
Default Trickle charger connection
Hi everyone.
Perhaps a simple question for someone to answer...!
I've bought a CTEC trickle charger that has a fast connection lead that can be left permenantly attached to the +ve and -ve terminals on my battery.
To use the charger whilst the battery is still in the car and its usual 2 leads attached... Can I simply connect the charger leads to their relative points, or, as the book suggests, should I put the +ve lead on the battery, but the -ve lead somewhere on the metal body of the car, away from a fuel line?
Advice please!
James...
Old 03-05-2013, 03:16 PM
Andy Roe
Andy Roe's Avatar
Hi James,
I just attached them both to the relevant battery terminals and it's been fine for about a yea like that.
Andy
Old 03-05-2013, 03:20 PM
KaiB
KaiB's Avatar
Yep. Install the quick connect directly to the proper terminals.
My CTEK stays on the (small race) battery every second the car is not in use.
Old 03-05-2013, 03:48 PM
Paul284pt
Paul284pt's Avatar
Same here!
Mine's been on 3 years as above with no issues and it works a treat.
Old 03-05-2013, 03:59 PM
Harry Apps
Harry Apps's Avatar
Ditto. Straight onto the battery terminals and make sure you fully close the bonnet (frunk) to turn the boot and engine lights off when the charger is working. Been doing this for 8 yrs+.
Old 03-05-2013, 04:31 PM
james_marshall
Great... That certainly will make it easy to connect etc... Hence the name!
Although... If I've got to close the bonnet completely.... How do I get power into the charger? I'm running it from an external plug on the house.....?
Old 03-05-2013, 04:37 PM
KaiB
KaiB's Avatar
Gently close it directly over the thin leads. It works.
Old 03-05-2013, 04:41 PM
chsu74
chsu74's Avatar
I had to drill larger holes to fit the Optima battery. Check first..
Old 03-05-2013, 05:40 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Yup - hard-wired directly to battery leads - works great.
Marc
Old 03-05-2013, 06:09 PM
james_marshall
Great stuff... That's what I had hoped for... I think I'll just stick to NOT reading the instructions from now on!!!
Cheers.
Old 03-05-2013, 06:13 PM
bigunit_271078
bigunit_271078's Avatar
That's how I read instructions as well. Good to see no issues if you just connect to corresponding terminals
Old 03-05-2013, 06:52 PM
964russ
964russ's Avatar
Ive bolted the wires to the battery, and fed them threw the wing to a front vent.
Small lead peeps out in fog lamp vent.
Old 03-05-2013, 07:00 PM
VR6-er
VR6-er's Avatar
Any pics?
Quick Reply: Trickle charger connection
