Ducktail???
That bracket is OEM Porsche - but I *think* they're NLA.
The bracket and its hardware come as part of the whole Turbo/RSA hinge strut which also includes the tubular portion (arm) and hardware. Their isn't a separate part number for just the bracket.
The part numbers are:
965.512.019.00 Left
965.512.020.00 Right
I would contact Sunset Porsche and ask them if they can find any of these kicking around - but they're pricey - like $200+ each side (!)
965.512.019.00 Left
I think I can speak for most on this forum... that's the kind of pollution we want to see more of!
We're here to fix these cars and share our experiences. Please feel proud and share pics with your 964 brothers!
965.512.019.00 Left
965.512.019.00 Left
-Don
Just ordered this from Amazon for $18.00:
Should be able to drill holes and find the other fasteners at ACE (our local ACE has a great selection of fasteners). May have to grind down the outside bolt heads for clearance.
I'll post the results.
JohnA
JohnA
Hey John, that's the stuff I used when I fabbed up my own initially - worked just fine! But then the OEM set came up on Ebay so I grabbed 'em.
One thing I'll tell you is that you'll need adjustability on every plane to do final fitting and get the gaps and positioning right once the tail is fitted. So you'll want the holes a bit larger than the bolts to allow for this.
Good luck and have fun! Can't wait to see it all come together on your '64!
John,
I have access to my father's machine shop in Tumalo, in case we need to create slotted holes for adjustment, and/or mill any edges of that L stock. It could be a fun basic machining project.
I'm pretty sure some of the vendors now produce ducktails with the correct hinge mounting points for 964/993. Check with Getty/MA Shaw, TRE, etc for specifics.
Bumping this thread because I need the brackets that are seen here with the red arrow pointing to it so that I can mount a RSA/turbo wing on my 964. Pelican only sells the entire hinge plus the bracket at a cost of $400 for the pair!!! Hoping someone has a set lying around that they aren't using. Or if someone could point me in the right direction to a company that sells just the bracket. Thanks for any help.
Rey
Rey
Here's a pic of the bracket you'll need (red arrow). I bought a used set of brackets and hardware from an RSA or Turbo (can't recall which). The original allen head mounting bolt location is the black arrow and you can see how far inset the new location is on the early style decklid.
The bits that I needed were the (2) brackets, the (4) bolts, nuts, washers, and spacer sleeves that mount the brackets to the original decklid arms. You can (barely) see (just below the black arrow) that the outer bolt head in flat to allow it to clear the engine opening. the spacers keep the bolts from crushing the original decklid arm as the nuts are tightened.
One other item is that the ground strap needs to be run up and out of the way tight to the arm (see ziptie) to avoid fraying and grounding to the ignition coils.
I've got 1 on mine, from fenn lane.
They moulded my original engine cover, so bolts straight on.
Phone them, they will make you one of my mould, I'm the UK thou, so probably no use to you!
Shamus
Getting ready to add tail - could you send me or post the measurement for the angle adapters. I can then fabricate for myself and also offer to members if they need. Figure I can make for under $50.
Thank you sir! Will contact them today.
Gus, if for some reason I can't get brackets from GT racing, I'll give you a holler.
