993RS steering wheel?!?
So I've done a search but wasn't able to find any solid answer. I've read that it doesn't fit because the splines on the shaft are different, but when I look up a MOMO hub it comes back the same part for the 964&993(7004). I know I will need to get rid of the airbag and the horn trigger will be used from a non airbag 964 but before I pull the trigger and order it up from my local Porsche dealer I wanted to confirm one way or the other. Anyhelp is greatly appreciated.
Also, since the 993RS steering wheel is made by MOMO I would assume that it would use its own version of the 7004 part that MOMO sells?
