Warning light help
They aren't hard at all. Use a pair of pliers to compress the cross shaped spring on top of the calipers, pop it up and pull the pads out. Compress the pistons with a screwdriver or other leverage implement and slide the new pads right back in. Depending on your particular car, there may be wear sensors that you have to remove from the old pad and put in the new (if they haven't been worn, you may(?) need new sensors depending on how far gone the pads are).
The ironic thing is since you just filled up the brake fluid reservoir, you'll probably have to siphon some back out (I use a turkey baster) while pushing the pistons in as this displaces fluid in the lines back into the reservoir, and could cause the reservoir to overflow (brake fluid eats paint, so avoid this). Probably a good time to do a brake fluid flush while you're at it. Slippery slope and all
IHI KING!
Topping it off with brake fluid did the trick! Amazing: I've been driving around for 4-5 months just ignoring the warning lights figuring it was just an "old car" thing. Nice to have them off again.
Now, do I attempt to replace my brake pads myself? Again, much harder then an '84 Porsche (or for that matter a 2001 BMW or '65 falcon - I've done all those brakes)?
