Car Vinyl Wrap DIY
#35
Your best bet is probably an automotive vinyl installer in your area, they would charge you much less than I would ,.....
#36
Hey cosmos, I dont do this for living. This is my first try at this. Based on the amount of time I am spending on this,.. it will take much more than a weekend. Beside, I have enough on my plate with being busy at work, my three sons, and my own car projects,...
I kind of figured that. I may tackle it myself while I have the engine out to take car of winter projects.
#37
Ok, sometimes this week I found enough times to do the rocker pannels and the shark fins. Now I am up against a bit of a dilema. I rellay like the all blue rocker and shark fin, but with all the bad roads and the constant re-asphalting of roads around here. I end up with tons of gooped up tar under the rocker. So I though I would try the upper half blue and the lower half carbon fiber (also vinyl).
What do you all think? Should I go all blue or with the lower half in carbon fiber look?
#40
Love the carbon look, would love to do my hood in the carbon look to prevent all those chips. Since the blue is so light, I think you will end up with quite a contrast between the carbon and blue when the rocker is on the car. Just carry a can of that goop cleaner around :-) Just my two cents.
#44
#45
I did the hood on Wednesday evening with a fellow PCA autocrosser. This would have been a real pain by myself, actually most likely impossible to do by yourself. And I had to throw the hood emblem on it right away.
The emblem stand much more on a ligher car.
