rennspeed front splitter installed with pics !
#32
Thanks for posting the pictures - and sorry for hi-jacking the tread a little earlier on!
It will be a while till I fit mine, but I'll post some photos too when it's done. Oh and really like the door seal trim to finish it off!
Cheers.
Cheers.
#35
Burgled
I like the trim around yours. I will look into doing that on mine when I pull them off and reglass the bottom of them. They grind down real easy if your car is lowered.
#39
Hi jotaking no the spoiler wasn't On the car I bought it from a fellow member in October had it painted and installed over Xmas. I. Also like the spoiler better than stock. For myself I like the look and think the 3.6 bridge wing is a good fit for the 964. Little by little it is getting there with a mixture of dollars going to maintenance and some to upgrades
#43
The wheels are the 996 17" 10 spoke. I Bought them last year and had them powder coated and also bought new center caps this year. Sorry I don't Know the et's off hand. Thanks for the positive feedback back. Now if winter would just hurry up and leave I could get around to driving it instead of just starting it up and sitting in it to hear it run
#45
Those that have used the rubber seals, can you let me know which ones you use... Is the the Side Sill rubbers, that run along the side of the car (externally) part number 96455929, or is it the door sill rubbers that are internal ( visible when you open the door).
How much of it will i need to order? Will just one side be sufficient for the 2 splitters?
Hope this makes sence?
James.
James.
