Bosch Design III injectors
Hi!
found a nice deal ebay and wanted to have some opinions about this. Price is tempting
http://www.ebay.com/itm/281042242874...84.m1423.l2649
I bought a set of those and they are Ford Branded and made by Bosch
I have not attempted the install yet
One thing to note that if the originals are slotted at the top for the bracket theses are not and will need to cut a slot to hold them into fuel rail
Also the set I got was not exactly as pictured..
They have the same max flow as the original injectors so I dont really see the point. Maybe mid range or part throttle improves due to the fine spray but would it be noticeable?
Porsche 0-280-150-731 = 18.45 lbs/hr , 193.9 cc/min , 139.5 grams/min , 3 bars , top feed , high resistance .
Ford 0-280-155-700 = 18.25 lbs/hr , 191.8 cc/min , 138 grams/min , 3 bar , top feed , high resistance .
VW 0-280-150-116 = 18.1 lbs/hr , 190.2 cc/min , 136.8 grams/min , ? bar , top feed , low resistance .
0-280-155-735 18.25 191.8 138 43.5 3
The "Ford" injector is listed as being from the 5lt V8 , 5000cc / 8 = 625cc
The Porsche 3.6 = 3600 / 6 = 600cc
The VW Vanagon & Porsche 914 2lt = 2000 / 4 = 500cc
No slotting necessary, they were direct fit.
I will try to start measuring mpg. My odometer went out soon after the install and have not checked yet. The car does run very smooth, but not sure if I can say the injectors helped with this. Sorry I cannot lend more feedback on them.
