Pulled the trigger on a 3.8 RS inspired 964 - development journal
Got 6,9,18mm thickness so I can try double it in places ie firewall ... Density of 45
Only issue is making sure the glue is upto the task re the aluminum, but it went on with little grooves and folds so lots to purchase on
Cheers Jack ... we're both graduating to over the 'big mod hump' together it seems
Sounds just about right Paul... I'll be back to that side of the equation in a week or two I hope
Here's my ground control to major Tom moment!
Idle DBs down from 78 to 72 ...
As the scale is geometric that's quite a lot ...
But the foil is mainly there to kill reverb and vibration...
Will be very happy if I get back or close to stock noise levels ie post cat delete and free flows ...
quieter than that and I'll get the wife and little one to come for long trips more often
Thanks for all the encouragement and kind words all
I know exactly what you mean, I love when we go on hols with my wife and kid...
Love your NASA STYLE space ship picture , I would probably do the same when I will fit RS carpets
You racing your GT3 in Extreme?
Did you source locally or eBay? Some I've seen is adhesive backed which provided the adhesive is good may be preferable since you'll use less spray adhesive.
Does the foam provide anything quantifiable in the way of sound proofing? Or is that all down to the left over wall paper from the mir space station
(Sorry HiWind)
The foam IS the main sound deadener from what I've read, with the bitumen-foil being there to lower reverb and transmission of rattles etc.. Effectively lowering the 'tininess' of the body. Per 80/20 rule you don't need to cover entire surface, just strips on 50-60% of the surface to achieve most of the density gain ... But it's more spaceship this way
KenD, Pierre: go ahead, perfect car - white, Carrera stripe, modeled on RS, M&R built engine ... Pierre's thread could have the same title as this one but w/o the 964
Pierre do you have a pic with yr 964 side by side the new one? Ps pm sent.
1. either I'm not going to have any of cell fon reception in the car, or
2. Houston, I'm ready for count down
3. I have Disco fever!
Foam & Carpet begins today.
Also will get a decibel reading at 2k revs - was 79 then 75, now ??? and then some open road tests too.
Now I shd add that the audio guys don't believe in covering everything with the bitumyl/foil products.
http://www.sounddeadenershowdown.com/ ... talking their own book to a degree
I figured that I'd use what I had bought and budget 5kg of new material - which is what I have here with a bit left over.
The science is that you can dampen reverb and vibration this way but you cannot barrier noise.
I was surprised by the (app store) decibel readings ... but they did drop and egine tone was noticeably less "airy"/windy.
But Mass Loaded Vinyl (MLV), while effective and Rolls Roycey is very heavy .. so for now I'm going with Velcro/Glue mounted closed cell foam.
