Brake backing plates C2 vs RS
Try as I might I can't locate a thread I've read on here about the difference between the two. A niggling memory says that they are interchangeable though the RS ones have better ventilation??
I ask because I'm getting bored with trying to patch mine up and figure I should just give up and replace them. I harbour a secret desire to upgrade to RS brakes at some point in the future so wonder whether I can start this by "upgrading" to RS backing plates? Alternatively, I'd like to install some non water-soluble non lead-impregnated aftermarket improvements. I'll bet that Humpty Dumpty has bespoke carbon-fibre jobbies.
Can anyone help?
Can anyone help?
Can anyone help?
Can anyone help?
they are bigger because the RS rotors are bigger 322 vs 298mm
turbo are bigger and heavier than stock ones
Rumour has it that braking in the wet (normal road driving) is adversely affected. Is this just myth?
Diameter doesn't sound like a problem. I know that the RS uses a different upright though; do you know if the mounting points are compatible?
Many thanks both!
Z
Many thanks both!
Z
![](https://forums.pelicanparts.com/uploads21/6_14_12_RS+front_backing+0011354717583.jpg)
Thanks Bill! Sounds like the best plan is to leave them off until I work out a need for them and buy a pair of those 993 ones. Are they stamped steel rust incubators too or does the silver colour suggest something more appropriate?
Technical Guru
To help prevent gravel & rocks & stuff from getting between the rotor and the caliper? If you were to drive a 964 in the rain, with and without, back-to-back you will notice a slight delay in braking (the best way to describe it might be; there is a miniscule but noticeable delay before the brakes "bite" during a downpour).
The Cup ones are aluminum
I didn't put a magnet on mine, they may be al. certainly they are 1/2 the weight of the standard 993 ones.
My concern was w/ heat at the sensors, this is a concern mostly for tracked cars, I did run w/o them for 5 yrs w/o issue
RSR used cut up stock ones
the upper 1/2 for 964Cup, these are al. and are feather light
![](https://forums.pelicanparts.com/uploads21/5_2_12_964Cup+frt_heat_shields+0011354733385.jpg)
the upper pair are exact dupes of 993RSR uppers, they are cut down stock rears(bottom)
![](https://forums.pelicanparts.com/uploads21/6_6_12_+0011354733418.jpg)
weights
![](https://forums.pelicanparts.com/uploads21/6_14_12_RS+_vs_stock_backing+plates_+0011354733449.jpg)
weights
![](https://forums.pelicanparts.com/uploads21/6_14_12_RS+_vs_stock_backing+plates_+0021354733474.jpg)
