Rear Center Light Substitution Panel
#211
I will gladly take all the money once I'm happy with the quality and fit of the panel. So far it's going very well. I have most of the hardware sourced. There will be some minor bracket fabrication necessary, but nothing I couldn't do with the tools at my disposal. I will start sourcing lights and harness next week.
One thing I need help with are the recessed black aluminium washers for Low-Profile Socket Head Cap Screw pictured below. Anyone knows who sells them?
Thanks!
Andrew
Thanks!
Andrew
#213
I think this is a great idea, but the hole pattern looks odd with the rows disappearing as they go outward due to the curvature of the panel. Maybe a different pattern to eliminate the horizontal rows?
#215
The mesh I am working with is just a prototype.
Thanks!
Andrew
#216
Originally Posted by FlyinTomato
what kind of trimming for the edge are you thinking?
#217
Black high-temperature rubber edge 1/8 - 3/8 trim. It will wrap around the edge and will be secured with M3 8008 Super-Black weatherstrip adhesive. From my research it is also the same trim that Magnus is using. Take a look at the Stance|Works photo at the top of this page.
Thanks!
Andrew
Thanks!
Andrew
#218
#222
Top to bottom:
- Cardboard mockup
- Prototype
- Hard template with mounting points to align mesh
All that to create Master #1
Silver bracket in the middle is in a prototype phase. The final 3 brackets will be black so they are less visible. The whole construction is quite sturdy.
BTW: Pattern is offset by 90 degrees on the Master #1 to hide any disappearing straight lines due to the curvature of the panel.
Thanks!
Andrew
- Cardboard mockup
- Prototype
Thanks!
Andrew
