Parking lights not working
Passenger side parking lights (front & rear) have stopped working.
Flashers, brake lights, turn signals work. Fuses OK.
Both rear tail light ***'lys replaced today so its not a bulb.
Any suggestions before I take it in? Thanks guys.
Are the fronts working?
There is a fuse just for the running lights. One for the left and one for the right.
EDIT: Make sure you check the correct fuses. If they're good, start at the tailight bulb holder and trace power. The harness probably has a connector/plug where it attaches to the main harness. It could also be the light switch with is a @#$% to get to.
The right front is not working either . . . checked and even swapped fuse 33 ( right running lights ), then checked all the fuses, then swapped the right & left front bulb - nope.
I think I'm going to take it in if there is no other easy trouble shoot.
