Is the LWFW setup something I should invest in for the 964?
I dont need this yet as the clutch seems fine. But my intentions are to drop the engine/trans within the next 6-months.
Therefore, I figured at that time I might as well convert over to a LWFW.
Is this the correct setup and is it worth doing?
https://rennlist.com/forums/parts-ma...ure-plate.html
Thanks in advance,
Steve
Thanks in advance,
Steve
PS...I know I need to buy some additional parts...like the LWFW.
I am assuming I will need to buy all of the parts listed in the notes section of this link:
http://www.pelicanparts.com/cgi-bin/...=PEL-FWC-C2C4N
Thanks again,
Steve
Thanks again,
Steve
I drove my car with the DMF, and a 94 C2 with LWF, back-to-back. There is a difference you will notice. Clutch-in, the engine spools up and down much faster. Clutch out, the engine pulls the full weigth of the car. You do not notice the LWF when the clutch is engaged. You will accelerate faster with less rotating mass, but not enough that you would notice.
The DMF is supposed to be better for smooth launches and less chattering in the drive line. I did not notice any difference between the two cars for driveline noise, and both launched off-the-line just fine. I will install the LWF mod if I ever need to drop the engine. Thankfully it runs great, and my budget is safe for a while.
Good comments, really helpful and clear info.
Super Duper Moderator
Track car - yes.
Street car - maybe.
YYMV with stalling problems, especially with AC on - not an issue in a track car.
I have one and would do it again but my car is 95% track.
Marc
Street car - maybe.
Marc
Having had access to both recently, the DMF makes street driving much less tiresome. With the SMF, the motor is terrifically responsive, especially its ability to rip off quick heel and toe downshifts.
I agree with Marc- track car for sure, street car maybe, and depends what kind of driving you're planning on seeing. (Even with a SMF chip from Wong- the motor does sometimes still die with the A/C- especially when the motor is cold)
OK i've got a question. I need a clutch in mine as the pedal is very stiff and the engagement point is at the top (Also is I dump the pedal it slips a little). Having a early 90, does the flywheel need to be replaced because if so It makes since for me just to get the lightweight flywheel. I think it would actually be cheaper.
