Mark this thread as Sold
New 964 RS pressure plate
New 964 RS pressure plate & clutch disk
Category: Drivetrain
Price (no $ sign please): $0
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 964, 993, 996, 997
Location (Region): Midwestern
Item Condition: Brand New
Will sell for $400 shipped in the lower 48 states. Condition is new, never installed. Out of box for photo only.
This is the 'blue stripe' 964 sachs pressure plate (note marking @ 6 o'clock in the photo). OEM part number 964-116-028-90, Sach's p/n 3082 213 133. Suitable for use w/ dual mass or RS lightweight flywheels.
According to the application guide, this fits all of the common non-turbo 964 variants ('89-'93, inc C2 / C4 / RS). The Turbo & 964 L/W use a different part but if you own one of those, you probably aren't reading this post nor, especially in the case of the latter, care that this is a significant savings over the various parts stores..
These threads describe the various 964 / 993 pressure plates, please confirm this is the correct part for your application:
https://rennlist.com/forums/964-foru...re-plates.html
https://rennlist.com/forums/964-foru...-your-lwf.html
***Sold, thanks*****
Can also include a sprung hub "RS" clutch disk for $300. p/n 996 116 015 32 (this part fits all 964, 993 & 996 / 997 GT3's w/ lightweight RS flywheels):
Looks like:
or, $700 for both.
Looks like:
or, $700 for both.
$600 for both.
Remaining required parts for RS clutch conversion:
928-102-151-01
Flywheel Bolt, 9pcs
944-116-080-01
Clutch Release Bearing
950-116-813-30
Guide Tube
964-102-239-31
Flywheel (RS, 11.5 lbs)
964-114-143-31
Ring Gear
900-067-103-01
Bolt, 8 x 45, 9pcs
931-102-111-00
Flywheel Pilot Bearing
928-102-151-01
Flywheel Bolt, 9pcs
944-116-080-01
950-116-813-30
Guide Tube
964-102-239-31
964-114-143-31
Ring Gear
900-067-103-01
Bolt, 8 x 45, 9pcs
931-102-111-00
