Short shift kit for 92-94
I had the same problems and modify the undertray, but there is an other rubber for this shortshift kit from Porsche its the same from the RS and cost €5,- so you wont have to modify the undertray. Its written here somewere.
Please show this link as I think you have the wrong information!
I dont believe you can install this without modifying the undertray, at least on a C4
Trevor, yes I will be doing this myself very easy job. But unfortunately it will not be done before Warminster, the Parts are Genuine Porshe from the RS model and have to be shipped from Germany (Pellican Parts approx $155 with bushings and c-clip). I should have all the pasrts in 3-4 weeks.
But I am planning on paint-wrapping the car,... Color most likely an RS mint green or baby blue,.....![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I talked to Mark from Specialty Cars on friday and he also brought up the wear on the synchros.
It was written in this subject:
https://rennlist.com/forums/964-foru...hifters-2.html.
regards,
Marco
regards,
Marco
On a 4WD car the only way you can have the factory RS shortshift kit installed and keep the undertray is to modify the undertray!
Were these issues most noticed on cars with solid trans and motor mounts,...?
More info on this Please.
The short shift is a standard RS part so I don't see why it would adversely affect the synchros, although that could become an issue if the driver habit was to constantly drive around resting their hand on the shifter as it is positioned closer.
Just reading elsewhere, you cannot install on a C4 without modding the undertray because of the propshaft, which means you cannot 'flip' the linkage as you can on a C2
http://www.type911shop.co.uk/shop/sy...3Dposition2%26
Shows a modified tunnel cover
I have a 94 c4 & want to install a short shift kit, any update to this thread? FD has sold me a couple for other 993tt's I've had, would like part #'s from Porsche or has anyone used FD's on a 964 c4, I'm aware of modding tray, my tech has done that before, just wanna get right parts, Thanks
