DIY headlight alignment?
Anyone have any tips or tricks for Headlight alignment? I cleaned my lenses and replaced the headlight bulbs this spring and made a real mess of the alignments.
Now that the sun is going down earlier I want to be able to see more than 20' in front of me
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
On the stock head lights, you remove the 2 small rubber plugs on the trim rings, and there they are at the top and 90 degrees to the side.
On the H4 lights you remove the trim ring and same as stock.
