Torque spec transmission mount C4
Hey guys,
could somebody of you please tell me the torque spec of the two nuts and the bolt from the trans-mount to trans-housing, the long screw through the trans-mount and the six bolts from the traverse to the body?
Please in NM, i´m always overwhelmed with your lbs specs![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
thx!
thilo
thx!
thilo
Just replaced my bolt through the mount (10x100mm, though there's a 12mm size for later mounts, per PET). Seems to have fallen out. Caused the same symptoms as a failing rubber center disk. Whew! I would put some thread lock on this one, or maybe even drill it and insert a cotter pin. Doesn't seem good to me to tighten against the aluminum ears on the mount.
You're smart to ask about the torques, although I'm sorry I can't help you. If you don't find th em, don't lean on the 6 bolts through the mount too hard. Threads can strip!
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
