964 Forum 1989-1994
Fan wobble
Old Aug 9, 2012 | 11:46 PM
Lord_Galva's Avatar
Lord_Galva
Default Fan wobble
I've been working on my dad's C4 for almost a week now. Couple of weeks ago the fan started "chipping" the housing at idle leaving nice marks on the bottom edge. It would get really bad if the engine speed increased.
I checked the shims and noticed 3 were missing. After buying the shims and reassembling the noise at idle was gone. However, once the engine speed increased, the noise came back.
I verified all the nuts and bolts were tight then made a discovery. The fan can wiggle about 5mm on the shaft. Is this normal?
Old Aug 9, 2012 | 11:50 PM
jimq's Avatar
jimq
Burgled
no. Its either the fan bearing or the alternator bearings.
Old Aug 9, 2012 | 11:52 PM
Laker's Avatar
Laker
yeah, what Jim said
https://rennlist.com/forums/964-1989...n-removal.html
Old Aug 10, 2012 | 04:21 AM
Lord_Galva's Avatar
Lord_Galva
Once I get the fan off should it be obvious which one is bad?
Old Aug 10, 2012 | 08:23 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Yes, it will be obvious. Once the fan is off, try moving the alternator shaft to see if it has any play in the bearings. Also use your finger to move the fan bearing. When you had it all apart, you should inspect the fan for cracks. In my case, the fan bearing was worn. I decided to replace the fan bearing, get the alternator rebuilt and have the fan powder coated while I had it out.
Old Aug 10, 2012 | 12:38 PM
Gus's Avatar
Gus
In my case the alt shaft was broken, which I found to be very strange - could not find anyone that had same problem - so had to replace alt
Old Aug 10, 2012 | 02:48 PM
Lord_Galva's Avatar
Lord_Galva
Ok.
The fan has a blade that has started to split.
I'll post a pic once I get it off.
Old Aug 11, 2012 | 05:52 PM
jimq's Avatar
jimq
Burgled
Originally Posted by Lord_Galva
Ok.
this is what mine looked like before i replaced it.
File Type: jpg
Old Aug 12, 2012 | 04:13 PM
altarchsa's Avatar
altarchsa
I've experienced both the alternator shaft breaking and a bad bearing. Symptoms are similar.
