964 Forum 1989-1994
momo wheel horn help
Old 01-29-2022 | 09:50 AM
spooky69's Avatar
spooky69
Originally Posted by dmaddox
Thank you - you are right, it was causing confusion as I have those two brown/white wires and I was trying to follow along. I also had to replace my turn signal assembly (I'll do a write-up on it) because the turn/cancel didn't work. I had to manually turn-off the turn signals.
Anyway - thank you, it all makes sense. I also did not (in my momo hub box) get the spare wire that connects to the ring. The only wire was the integrated wire inside the hub. Not a big deal, I'll just make one.
Thank you for the help!
My turn signal was not cancelling with the original steering wheel but simply fitting the hub adaptor and new wheel seemed to fix it. I've no idea why.
Quick Reply: momo wheel horn help
