My 964 is making a strange noise. Video inside.
I think the noise is coming from my clutch.
'91 C2 over 78k miles. I do not know if its the original clutch or not.
It started out intermittent, but is happening more often. When I start from a stop (1st, reverse, or even 2nd with enough revs) the sound begins. I first thought it was a tire rubbing. When the clutch is being released, at the very top of the pedal, it makes this noise. I'm not sure if you can tell from the video. Sounds like something is rubbing.
The noise is not present when the clutch pedal is fully engaged, only when being released, at the very top.
The noise doesn't appear to affect driving. The clutch pedal feels fine and returns normally.
I've tried doing some research, but I haven't come up with much. Is my clutch going out? Is it the slave cyl.?
http://youtu.be/ju27lae_GTs
IHI KING!
That is an odd sound. Have you tried jacking up the rear of the car and listen while someone manipulates the clutch? While you have the car up, I would also double check the axles, wheel bearings and engine mounts. I doubt they are the cause but it would be good to be sure.
IHI KING!
It sounds like a noise made by something spinning to me, so I doubt its engine mounts but if you have the car up already, why not check everything.
Another thought, when you have the car jacked up, also check the transmission fluid level and CVs. Also, does the noise occur if you let the clutch out when the transmission is in neutral?
That worries me. I would think if it was something serious, the noise would be present all the time. The gearbox doesnt make any noises, and shifting is smooth.
I guess I'm just going to have to suck it up and take it to the dealer.
The closest dealer is in Charleson, WV. I'm in the Kentucky/Ohio/West Virginia Tri-State area. Is there a good source that lists Independent shops?
I took my father out in the car to let him have a listen, as he could provide some insight. It made the noise when he got in as I drove away, and didn't make it again for the rest of the drive.
He also seems to think it's a throwout bearing.
