964 Forum 1989-1994
ignition switch
Old Jul 18, 2012 | 12:05 AM
cobias1's Avatar
cobias1
Default ignition switch
When I crank my car is the ignition switch supposed to spring back into the number 2 on position? with all other cars this is built into the switch but I know this is unlike all other cars. looked into the forum already and there is a ton of posts with ignition switch somewhere and everywhere in the posts. I just want to know if it should kick back to pos. 2 or does everyone just "manually" place back into pos. 2. Thanks in advance for any replies.
Dan
Old Jul 18, 2012 | 04:27 AM
DaveK's Avatar
DaveK
It should move back automatically - you shouldn't have to do it manually.
Old Jul 18, 2012 | 11:43 AM
Indycam's Avatar
Indycam
You need a new electrical section . The spring is not in the lock , it is in the switch behind the lock .
Old Jul 18, 2012 | 10:52 PM
cobias1's Avatar
cobias1
thanks guys...the confirmation helps alot. thats going on the to do list under b section after the shocks and spring plates get on and I do my valve adjustment. thanks again.
Dan
Old Jul 18, 2012 | 11:19 PM
Silvertarga's Avatar
Silvertarga
Just did this a while back..make sure you lay a towel under the lock to catch the screws if they fall. I used a magnetic screw driver but one still fell off, the towel caught it before it fell into the nether regions
Old Jul 19, 2012 | 11:00 AM
Indycam's Avatar
Indycam
Dan
It should be moved up to number one on the list , imho .
It is not a big or expensive or dirty job .
Old Jul 20, 2012 | 09:46 AM
cobias1's Avatar
cobias1
point taken and appreciated indycam...just have the parts as of now to do the other things that i listed before so this part has to go on order for me to be able to do it. Thanks for the opinion though.
Dan
Old Jul 20, 2012 | 11:43 AM
Indycam's Avatar
Indycam
When my switch did the same thing yours is doing it was a safety problem .
The switch was endangering ...
I would not press you to do the repair without good cause .
96461301200
Genuine Porsche
Ignition Switch
1 per car. $85.98
Old Jul 22, 2012 | 03:24 PM
cobias1's Avatar
cobias1
Im looking into it now Indy..thanks again for the advice. Right now Red October is parked at least until bump stops come in for the rear struts and spring plates get here too. will see how the week goes and possibly order one early next week.
Old Jul 30, 2012 | 03:00 PM
cobias1's Avatar
cobias1
I ordered an electrical section from a local parts place here. Took a look at it and just dont quite understand how the spring is located there to make the key itself return to pos. 2. If you say it worked I truly do not doubt what youre saying and maybe it was the wrong electrical section, there were no moving parts on this for sure, that I could see anyhow. so I guess im trying to get some explanation as to how the electrical section corrects my problem.
Dan
Old Jul 30, 2012 | 03:19 PM
cobias1's Avatar
cobias1
also, how far of a movement is it from start to on position. There again it moves back a little bit and maybe right where its supposed to be. Thanks again for the help.
Dan
Old Jul 30, 2012 | 09:14 PM
Indycam's Avatar
Indycam
On my 89 C4 , the switch had the spring in it , when I put a screwdriver into the slot and turned the switch I found the spring was inside the switch .
"Ignition Switch (the electronic part)
Brand new Genuine Porsche part, in stock, ships fast.
Don't fall for the cheaper aftermarket versions - they are junk.
If you can't feel the I, II, and Start positions as very distinct resting points while you are turning the key, then this switch is probably broken since it has the detentes and contacts inside."
