Porsche 964 headlight parts
Hello,
im looking to find out the part number for the following parts.
the adjuster screws that connect the headlight assembly together they screw in to plastic fitments, fairly long bolts. Once you take the headlight rim off you see them. assume they are for adjustment.
Im also looking for allt he plastic clips that they screw in to.
anyone have any idea where ic an get them if at all?
Thanks in advance
David
Thanks in advance
David
Hi David,
I found a link to the 964 PET parts catalog. Have a look at page 525 for the part numbers
http://pcbunn.cacr.caltech.edu/jjb/P...SA_KATALOG.pdf
Be sure to check they're the same lights as you have as in the US they are different to the ROW.
Andy
Andy
