UK experience with taillight tint film. MOT?
Hi, I'm hoping to go for Gus's marvellous magical mystical tail-light and centre strip healing film (TM)..however, has anyone in UK used this and passed MOT without problems?
I can live with the pink back up lights, but my main worry is indicators not being 'orange enough' (I have had a fail on that with smoked side repeaters before), but also that the tail lights and indicators already arent the brightest in the world..
Maybe brighter or LED bulbs would be a start, I should maybe do a search on that as I'm not up to speed. I dont think the tailight units open up so I cant put foil in the light housing like the early 911 guys do..
This has been covered in previous posts, but I wondered if any UK listers had any new experience to share?
I use Gus's film on the center section and had no problem passing an MOT last Sept.
But I was never happy with it on the turn signals; just because most UK drivers would not associate a red light as a turning signal.
Yellow bulbs don't help, nor did the LED's I tried. Someone mentioned cutting out the red film where it goes around the orange turn signal area and substituting with an orange film section. That sounds like it should work![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Might be worth asking Gus if he has any orange film...
i fitted my own red adhesive vinyl film sourced off fleabay and some orange film over the indicators. it's easy to do, you don't need a "kit". the reverse light in white/clear is not an M.O.T requirement so i left it red. you can also do the whole lot in red and source green indicator bulbs which will shine orange through the red film. Film was £10 delivered and i have enough to do my new c2 when it arrives, so £5 a car. (orange film was harder to source but again fleabay came up trumps via a seller in Hong Kong)
