Torquing bolts
Does anyone know the torque setting for the little bolts that hold the timing chain covers, the valve covers and the intake stacks. Trying searching Internet but nothing comes up. Already over torqued and stripped one bolt so looking for the correct setting.
Not sure about the stacks, but the valve and timing covers are like 7ft/lbs. Use a small 1/4" drive ratchet and only get them wrist tight. Or you can get yourself an inch/lb torque wrench.
