964 Forum 1989-1994
do a little happy dance?
Old 06-04-2012, 02:22 PM
jimq
Burgled
jimq's Avatar
Originally Posted by hawk911
so... if I replace the timing chain tensioners, it looks like they are still $225 a side. Is that right? and then the rails are $50 or so a side? Am I looking at the right parts?
Left:
964-105-079-00-M40
964-105-029-00-M260
Right:
964-105-080-00-M40
964-105-030-00-M260
and what about this part?
964-105-043-02-M260
all prices from Pelican, page 1 or 2 from the engine section: Pelican engine parts section
try Sunset prices. Last couple parts I bought were a lot cheaper than Pelican. I replaced the rubber part for air on top of the fan a couple weeks ago and it was $30 less at Sunset and fit perfect.
Old 06-04-2012, 02:36 PM
hawk911
hawk911's Avatar
for close to $750 if I did both sides, I'll for sure call around. The prices did not include a new chain. Should I bother, or are the chains bulletproof?
Old 06-04-2012, 03:03 PM
Makmov
Makmov's Avatar
Probably wont ever break a chain but they do stretch out causing the cam timing to go out of ideal spec.
If it was me I would just do the chains too.
I like to do things once so I DRIFT.
Old 06-04-2012, 03:11 PM
hawk911
hawk911's Avatar
now... how much undertray should I run with? I have it ALL off right now, and the 2nd piece from the back (that covers the transmission) was cracked and is now in 2 pieces.
Old 06-04-2012, 03:15 PM
Makmov
Makmov's Avatar
The tray was for euro noise abatement and aero under the car.
You are probably fine running whatcha running
If you wanted to put the tranny cover on that would be okay as long as it's not fluttering around
I have no trays in the back on mine and have seem to have had any problems running that way, and I have done a long sweeper at 120+
It got a little wiggley in middle with the old stock suspension. Like glue with Bilsteins and H&Rs lowered, so I guess the little pop up wing is enough.
I could see people a head of me looking in the review mirror thinking there was going to be a huge crash when the seen me coming that fast and just got out of the way.
Old 06-04-2012, 03:16 PM
hawk911
hawk911's Avatar
I have the trans tunnel/shifter area covered, but nothing else. Will I see a 10hp butt dyno gain?
Old 06-04-2012, 03:54 PM
Makmov
Makmov's Avatar
Yeah, sure, just keep thinking that so you sleep at night ROTFLMAO
Old 06-04-2012, 04:30 PM
LouZ
LouZ's Avatar
Location: Philly Area ----- George Washington took a dump in my backyard!
I don't believe that it's too easy to replace the chains as the one set of gears are in the casing. Also, when I did my rebuild, the curved rails were worn to the point of warranting replacement, however the flat rails didn't show enough to replace them.
You will need to retime the cams if you replace the rails, and that will pick up any chain stretch that occurred.
Quick Reply: do a little happy dance?
