Scantool ABS/PDAS error #43?
hey all - had my ABS/PDAS warning light/buzzer come on yesterday two different times. Ran my scantool on it today and it reported error code #43. The problem is that the code descriptions only go up to #40 - does anyone know what #43 is?
Is this what you have as for descriptions?
11=Lateral lock valve-No feedback signal from valve to control unit
12=Lateral acceleration sensor short-circuit/break in circuit
13=Lateral acceleration sensor-implausible signal
14=Lateral lock-deviation in regulating values
15=Control unit defective
21=Front left speed sensor
22=Front right speed sensor
23=Rear right speed sensor
24=Rear left speed sensor
31=Front left ABS valve
32=Front right ABS valve
33=Rear axle ABS valve
34=Valve relay
35=Return pump
41=Front-rear differential lock valve
42=Front-rear acceleration sensor short-circuit/break in circuit
43=Longitudinal acceleration sensor-implausible signal
44=Front-rear differential lock control diviations
45=Full differetial locking button
34=Valve relay
35=Return pump
The 964-type Trouble Codes file have to be renamed to Trouble Codes.txt in order to let Scantool use it. This file contain all 964 fault codes.
Cheers,
Tore
Cheers,
Tore
