What have you done?!?!?!?
Replaced front a arm bushings
replaced front wheel bearings
replaced fuel pump
replaced oil tank oil lines
replaced engine mounts with Wevo mounts
replaced transmission mount with Powerhouse mounts
reinforced engine mount crossmember with Rennsport RSR mount kit
Euro RS shifter
new oxygen sensor
new distributor
two tune up kits
993 steering rack brace
Bilstein shocks
H&R Red springs
recovered drivers seat
New windshield
front brake ducts
Gas tank sender unit
Rothsport RS single pully kit
Rothsport Aluminum pully half
Ruf Speedline wheels in black 8x17 9x17
Front 928 S4 brake rotors
EBC Brake pads
G pipe
engine sound blanket
remove all brake backing plates
replace 5th and reverse gear parts
front strut bar
new bosche ignition coils
replaced fuel pump
Euro RS shifter
new oxygen sensor
new distributor
two tune up kits
Bilstein shocks
H&R Red springs
New windshield
front brake ducts
EBC Brake pads
G pipe
front strut bar
Breather Gaskets and Hose
Temps Sensor crush rings
Alt/ Fan bearing
H&R Greens / Bilstein HD's
Braided Brake Lines
993 Steering Rack Brace
993 RS Steering Wheel
Clear Lens / Removed Blocks
Rear Lens & Reflector
Right side A/C Fan
Fuel Pump
200 Cell Cat & Primary Bipass
Nylon Shifter Bushings
Shifter Boots
PDAS Slave Cylinder Gasket
RS Door Panels
Door Stops
Hood & Boot Struits
Spoiler Curtain
Cleaned Intake Manifold &
Replaced Rubber Sleeves
Steve Wong Chip
Alt/ Fan bearing
Braided Brake Lines
Right side A/C Fan
Fuel Pump
Shifter Boots
RS Door Panels
Door Stops
Hood & Boot Struits
Spoiler Curtain
Steve Wong Chip
