No Idea!!!
No Idea!!!
I change rotors and cap change spark plugs and ignition wire but the problem persist everytime i get a bump the engine cut power!! It is doing it less but it bothers!! How can i test the coils??Someone has this problem??
Help
Help
Sounds random I know, but have you recently replaced the chip?
I had the same problem months after I installed my 93 Octane chip. I didn't push it in hard enough and months later it would die after hitting a bump in the road...searched all around the car for problems before I found this simple fix.
Actually my shop found the problem...I was just about to remove my fuel pump! Glad I threw in the towel before doing that.
http://www.pcarworkshop.com/images/b...0590geolab.pdf
Here is a link to service bulletin for the afm wiring harness. You should check to see if yours has had it done. Might or might not be the problem but wouldnt hurt to check. Good luck!
Formerly turbotwoshoes
Check and clean all the grounds.
If I am not mistaken, there are grounds attached to the bolts behind you coils, and others around the engine bay. If I recall, i found liek 8-10 different ground points for different items all over the engine bay and under the frunk lid. All of mine had white residue corrosion (I live in a wet environment and suspect that my car had been swimming in an earlier life, but no direct evidence).
After I have cleaned al lthe connections, I have not had a problem since.
Best of luck. Jack
Best of luck. Jack
