oil temperature sender
So my car oil temp went to 10 o'clock for the first time ever, 217k miles, and so I turned on the inside fan high just like I used to do with the MGA. It brought the temperature down.
In troubleshooting I think I have isolated it to the temperature sender from the oil cooler. I get about 4.6 K ohms when warm, goes to 1.6 k ohms when near the point to operate the fans, and then goes to 6 k ohms as it got hotter.
weird. I thought it should fail safe. go to 0 ohms closed circuit!
+1 mine was breaking apart. Easy fix.
Also check the ceramic resistor on top of the fan housing cowl.
2nd unit from dealer was correct size, car running fine and cooler fan works.
strange that the device failed into a no-safe position.
Dealer was puzzled how the part with wrong thread had same part number.
