OBD2 converter cable
http://www.ebay.ca/itm/320757812557?...84.m1423.l2649
Will it work with our cars - looks like it should fit.
True the 19 Pin OBD1 will plug into the car and the OBDII will plug into a reader.
However, you will need a scanning software that will actually read the codes. Chances are you will get basic codes, perhaps but any of the other moduals you probably wont have access to: like Airbag, ABS, C4 beeler opperation, Alarm, and HVAC systems.
I haven't actually tried it so I don't know.
I do have a Durmetric and the only thing it doesn't do that the Bosch hammer will is the Adaptation.
Based on my limited research you would be better off buying this one for $10 more and get an interface that works:
http://privat.bluezone.no/toreb2000/t-productsEN.html
Thanks carlskisWP. My 19-pin adapter cable is tested throroughly.
Beware, most of the ebay items have wrong pin connections and won't work in a 964. I have not seen them working in any Porsche cars actually.
I have tried to dig deep into pin connections with a lot of Chinese eBay sellers, most of them don't understand my questions on these details. I can't understand how they can keep up the business around these when they are not connected correctly.
Cheers,
Tore
Cheers,
Tore
I do have a USB OBD2 cable so i was hoping this would connect via the usb port then use the scantool software via the two cables - the 19 pin OBD"1" adapter to obd2 connector to USB.
That cable is not good unless your have a durametric? scanner.
IMO don't waste your money on that one..
Search for the threads about the scanner many of us have bought and works perfectly fine!
Good luck!
Good luck!
i have scantool installed with a homebuilt interface that works fine as well. The only thing i don't have is a proper plug to connect with - i use four pins and plug them individually into the car. If the cable doesn't communicate i might just chop it off and use the plug so that i don't hve to fiddle with the pins.
