964 Engine failure - need suggestions!
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
After 144k miles, my stock 3.6L let go while doing a DE last weekend. The motor is destroyed, including a cracked case. I don't have all of the details yet, but looks like a rod bolt may have let go. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Over the last couple of years, I have been slowly adding some track goodies (mostly safety equipment) and using the car primarily for DEs. I like to participate in about 10+ days / year of DE.
The car has a brand new RS clutch/flywheel (<100 miles on it), RS motor mounts, H&R Springs, seats, BK Harness Bar, and harnesses - all installed within the last few months. The car is very clean, straight, no accidents, etc...
So now I am faced with some decisions, and would like to solicit some recommendations. I am definitely going to continue to do DEs, so that is really the only requirement. Some options that have been presented to me are:
1. Buy a reman or used motor, slap it in, and go for it...
2. Build a motor from pieces, a little stronger, for track use.
3. Ditch the car as, is, without the motor and get something else (like a Cayman, or 996GT3)
I'm trying to keep an open mind, so any suggestions will be appreciated. What do you guys think???
Thanks,
Thanks,
+1^... do yourself a favor and have a conversation with Steve at Rennsport 503 244 0990
He's got a lot of options that can get you a ton of enjoyment out of your motor... a rebuild can be a great occasion to really do it up right. Kai's motor build is a platform for a number of streetable options that you can choose from. You don't have to spend the same kind of money to really get some performance.
At least you'll have data to inform your decision.
Sorry to hear this. My C2 motor failed last year and I was gutted.
I looked at getting a used motor and swapping it out, but after weighing the costs and getting invaluable input from some great people on the board, I decided that the cost was still close to a rebuild and I would still have the risks of an unknown, high mileage engine AFTER I had paid the bill. I found a highly respected rebuilder locally who believed they could do the work quickly and far below the initial quotes I had gotten (apart from the ones by motormeister of course, but after the professional and first hand stories I received, I wouldnt allow them to change my oil).
I'd shop around on rebuilds or rebuilt motors and weigh the cost against the other options before making a final decision.
Good luck - I feel your pain.
All the best,
--Howard
All the best,
--Howard
Rebuild. You'll know exactly what you have and your cost will be same or less than buying another motor and certainly less than buying a cayman or a gt3. If you are going to track a car, you should already have in mind that costs for damage and maintenance will pile up. Just keep rebuilding and having fun.
If you have done the case, crank and the rest of the bottom end, part out the top end of the motor and buy a used engine to replace it because it is going to work out cheaper than sourcing the new parts to repair what you have. Once you find a new engine, then make the decision to rebuild it or fit it, depending on available budget and perceived risk from the vendor.
#2 - because you'll know exactly what you have
#3 - not an option because financially you'll get hosed.
These motor failure threads are depressing
That sucks.
Opt. 2
Get a used motor and build to the purpose it's going to serve.
Stock rod bolts are a known weak link for DE and track use. There are alternate options over the stock bolts.
Opt. 2
Bite the bullet; call Steve right now and go over options. Do your best to remain on budget, but many cool options are out there now - some weren't aval a year ago.
If you see Club Racing in the future, be very careful about your build if you want to run in stock classes - otherwise you'll end up in GT (and can come play with us!!!)
Edit to add: The 964 is a wonderful platform, and if, like most of us, yer heart is in the car...this is the right choice for so very many reasons.
The new cars are just not as robust - and damn sure not as sexy.
Thanks everyone for the suggestions and responses. Especially Kai - thanks for the call yesterday - I really appreciate your time and perspective! ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
I know most people mentioned to 'stay on budget' - the issue is that this was not budgeted, so my budget is equal to the least amount of $ that will get me on the track "reliably"... Don't want to be in this same boat in another two years.
I was leaning towards #2, and it looks like it is pretty much unanimous. So I did call Steve W yesterday. Great guy and very helpful. Spent a lot of time with me going over a lot of what is involved with a build. He is going to get back to me with an option or two.
Looks like this might be a long road - guess I am going to have to put one of the 928s into DE duty, at least for The Glen this month...
Thanks again, and if anyone has any more input, I am all ears!
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
