964 Forum 1989-1994
AC Update
Old May 1, 2012 | 07:19 PM
VR6-er's Avatar
VR6-er
A lot of good info here.
http://rennaire.com/
Old May 1, 2012 | 08:00 PM
-nick's Avatar
-nick
Griffiths gave the low-down. I'll add that just about decent shop should have the equipment to evacuate any remaining R12. This is your first step. A corner shop charged me $20 and kept a vacuum on for about 20 minutes to see if it was losing any pressure.
Next is to buy the orings, new ports, new drier, oil, and freon+dye. Replace as many orings as you possibly can. You can "rent" a vacuum pump and AC manifold gauges from many auto parts stores. After replacing the parts, put the vacuum on it, then charge it up. It's really a pretty easy process. The trouble is when you discover that you've lost all of your freon a week later
Old May 2, 2012 | 03:33 PM
griffiths's Avatar
griffiths
This will help you along 964 AC Parts
Old May 2, 2012 | 05:22 PM
GazC2's Avatar
GazC2
Cheers for that its all a bit clearer now, I have a man in a van coming to the house to check out the 964 and also the ML as it only holds a charge for about 3 months had the dye through it 3 times and cant find anything wrong.
Old May 2, 2012 | 06:01 PM
griffiths's Avatar
griffiths
If you are losing the entire charge in 3 months that is a MAJOR leak.
Ask the chap in the van to use an electronic leak detector and to sniff the vents.
