Stiffer shocks and springs
Wondering if anyone has re-valved Bilstein HD's and added stiffer springs with great results. I am currently running Bilstein HD and H&R greens. Someone has suggested RSR re-valve with Eibach RSR springs.
thoughts
thoughts
I have not done it on a 954, but I had Bilstein on my 944S2 race car that were revalved several times based on the spring rate. However, I was running 700F and 900R.
You should talk to a shop who has a realtionship with Bilstein and has knowledge of the set up you are considering on 964. You should figure out thee spring rate you want and whether you have other options that may be cheaper, more suitable.
