Problem in opening Motronic box
Hi all,
Just like title says, I'm not able to open my motronic box. I'm following Steve Wong's instructions. I released the plastic latches with screwdriver. Upper board was released but I'm not able to move it fully from the slot.
I can move it backwards approx. 1cm but then the left side gets stuck.
and advise?
Cheers,
Mikke
and advise?
Cheers,
Mikke
I've done mine twice. Each time took a bit of carefull fiddling, but worked.
If you mean Steve Weiner, good. But...if Wong, go to his website and follow the instructions and pics there. Be careful and insure you fully see what you're trying to release before you do it.
