964 Forum 1989-1994
Engine Braking - odd symptom
Old Apr 11, 2012 | 04:01 PM
timatt's Avatar
timatt
Default Engine Braking - odd symptom
'89 C4 57k miles.
When decelerating while in gear, clutch engaged, foot off both the gas and brake, engine braking occurs as expected for, however as RPMs drop the car will momentarily speed up - like a slight throttle blip - then continue decelerating. If the RPMs are high enough, I might experience 3 or 4 of these slight throttle blips even though I'm not touching the gas pedal.
Can this be a problem with the ISV??
Old Apr 11, 2012 | 04:06 PM
Vandit's Avatar
Vandit
Are you running the heater?
Old Apr 11, 2012 | 04:45 PM
dfinnegan's Avatar
dfinnegan
Perhaps the idle microswitch is making, and breaking, contact?
Old Apr 11, 2012 | 06:03 PM
Andy Roe's Avatar
Andy Roe
It could be a broken throttle return spring or sticking throttle cable? There should be a spring that returns the throttle back to idle once you take your foot of the accelerator. Perhaps if this is broken, the throttle isn't returning to idle properly.
If you look in the engine bay it's a spring next to the end of the throttle cable. This set up is only on the earlier 964 engines and unfortunately I don't have a photo of it to show you - maybe someone else will!
Old Apr 12, 2012 | 04:56 PM
tbennett017's Avatar
tbennett017
+1 IMHO... this sounds right. With the car off, you can listen for the microswitch to click as you move the throttle on and off idle. I'd check that soon.
Old Apr 12, 2012 | 05:12 PM
August West's Avatar
August West
Seems like you could rule out the idle microswitch if you do your usual engine braking but keep the throttle slightly depressed, as if you were attempting to run the engine at 1000 rpm or so. This would keep the microswitch from activating and if your car still behaves poorly, then you can probably rule out the microswitch.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
