Happy Friday - Dodged a bullet - Plans for the weekend?
IHI KING!
For the past few weeks, I've been driving my cabrio after a 2 year hiatus. Its been a real pleasure except the steering has felt a bit loose. Last weekend, I jacked up the car, expecting to need to install new tie rod ends. But upon inspection the tie rods looked fine and tight. But I could still feel slop in the steering wheel. It would move about 2 minutes if it was a clock. I then checked the rack to make sure it was tight. It was. Hmm... Next we pulled the floor board to inspect the steering column universals. Aha! The lower universal joint bolt had backed off. It was 1-2mm loose. I removed the bolt, cleaned the threads with a die and reinstalled it with red locktite and a torque wrench. The steering is as good as new. I'm glad it was a simple fix. Its a bit scary to think what would happen if the bolt fell out and the shaft separated while driving. Eek! ![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
This weekend, I will be troubleshooting why my fog & backup lights don't work. The fuse blows as soon as I turn on the key to accessories. I suspect its a fault at the backup light switch. I also need to figure out why my GF's Honda has left two small puddles of coolant on the garage floor. I suspect the car may need new radiator hoses. I'm hoping its not a bad radiator.
My GF is taking me to California for 9 days for my 50th birthday. We will be starting in SF visiting Alcatraz and the trolleys. Then the redwoods and a winery. We will be staying with friends while in the Bay area. After a few days, we start driving down Pacific Coast Highway visiting Big Sur, Hearst Castle, Vandenberg AFB and Santa Barbara. I'm looking forward to it.![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
What are your plans for the weekend?
IHI KING!
Why a 2 year delay? I had made an error replacing the alternator where I hooked up the wires backwards. It burned the wire harness.
I was trying to decide if I was going to repair or sell. Meanwhile, I was driving my coupe. In the end, I decided to rebuild the engine but am doing a bit of shuffling. I took the engine from the coupe and installed it in the cabrio. I am in the process of rebuilding the engine with some mods to make a better track car including LWF, RS cams, a SW chip and j-pipe. I have purchased a used wire harness for the rebuilt motor.
While I'm at it, my GF suggested that I should get some track seats and a roll bar. I purchased some used GT3 seats. They arrived yesterday. I'm heading down the slippery slope on the coupe.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Yard work. Car work. GF work. I thought work ended on Friday?
Rob, if you haven't been down the PCH before, it's a beautiful drive. All of the places you're going to hit on the way down south have gorgeous views! Hope you have a great birthday!
Rocket Rob: Speaking as an ex California surf rat, slippery slope are the ONLY way to go! Fret not though, the greatest # of slippery slopes of your type do ultimately end in success. Replacing that wire harness does NOT sound like fun. My condolences.
Started the search for a replacement TIP! A little history for those that have not read some of my recent posts: rebuilt the engine and mated it up to the TIP. When I installed it and fired it up, I had absolutely no power to the drivetrain. Last week I pulled everything out.....again!
Pulled the engine and I split the trans mission and torque converter to have a look/see.
Well in the shaft where the torque converter mates to the TIP, I found bits and pieces of what used to be the shaft key. The race is scored and I can't even tell if the fluid pump works.
So now, I won't even bother to attempt a repair because I can't be sure if any metal migrated into the the torque converter or even the TIP.
DC Auto & LA Dismanteler both have replacements so I will likely pull the trigger on Monday.
