Oil Pressure Gauge - What's the correct behaviour?
Hi is it normal for the oil pressure gauge to fluctuate? Or is this an issue? Dogdy gauge or worse!?
My first 964 and was told by the seller it was normal?
Just checking, thanks.
On a healthy engine, at idle you'll see a steady 2-3bar when cold, 1-2bar when hot. By about 2000-3000 the needle should pin at 5 bar. If you are seeing quick up and down movements of the needle, you may need a new sensor.
Normal is in the neighborhood of 1 bar per 1000 RPM hot
In addition, I found that with aftermarket gauges the needle bounced around (especially on idle). When I replaced it with an original item purchased from Porsche, the needle was rock steady.
The pic below shows two aftermarket gauges on the left and the Porsche original on the right:
