964 Forum 1989-1994
Weighted Shift Knob
Old Mar 29, 2012 | 10:46 PM
Goughary's Avatar
Goughary
Default Weighted Shift ****
Just installed - big difference in feel. Fits well.
Part #'s
**** 993.424.075.004 YU
Rubber Shim 931.424.111.00
Rubber Shim 931.424.110.00
Clip 993.424.299.00
This comes from a 6 speed car, so you need to swap the black cap on your shift **** with the silver six speed cap that comes with this one. I found a new 5 speed cap and used that.
File Type: jpg
Old Mar 29, 2012 | 11:06 PM
jody stowitts's Avatar
jody stowitts
Goughary: Where from, do the change yourself,and $ if you don't mind. Thanks.
Old Mar 30, 2012 | 01:25 AM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
What is the weight difference?
Marc
Old Mar 30, 2012 | 10:02 AM
Goughary's Avatar
Goughary
Weight difference is huge -the standard one is very light. Cost was sub 300 dollars- i dont know the total. Ordered everything from Sunset. Careful with the last letters on the **** part# - those are the color code. I changed it myself yes, very easy to do. 15 mins. 5 mins if you have done it before. I hadnt so I took my time...
Mark - for what you are putting together with your car, I'm not sure which **** would be better. The standard **** is slightly smaller, and you will be wearing driving gloves, so the size may be better small. Plus, the smaller **** fits on with a molded rubber housing that is very tight to the shaft, so there is very very little movement between the **** and shaft and a less dampened touch - ie, you feel more through the **** with the smaller one. The larger **** touches the shaft only in two points, as there are two soft rubber bushings that is rests on - one at the top and one at the base of the metal insert. Those soft bushings are nice for the street, makes every clank, a clunk, if that makes sense. but there is some give and movement when shifting. So before spending the money, I would try to get ahold of someone with a 993 TT or someone that has dont this upgrade and try it out first hand...I could probably explain better if I werent writing...
However - for street use - I am more than happy with it. Hope any of that helps...
Old Mar 30, 2012 | 02:21 PM
jody stowitts
Goughary: Thanx for info! P.S., which method did you use to rem. old & insl. new? i.e., lever the metal retaining rectangular ring (of the leather boot) out from above, with a fairly wide thin nosed screwdriver, or remove the whole console frame and remove it from below. I'm going to do this in future, but am a bit spooked about BREAKING the 2 retaining clips away (off) from the under side of the "vulnerable" plastic console frame to which they (the 2 clips) are attached. P.S., which side (L or R) side are the retaining clips on, and how far away from the corners, in your estimation? Mucho thanx!
Old Mar 30, 2012 | 02:39 PM
Goughary's Avatar
Goughary
screw driver under the lip on the left side - lever down carefully - I stuck the screw driver between two credit cards to keep it from hurting the console or the leather. Easy enough - once it starts to move it pops right off. then wiggle it out and then the tricky part is you gotta work to pull off the old ****. the rubber just doesnt want to le go. But eventually it worked itself up and off...Hope that makes sense...
Old Mar 30, 2012 | 06:48 PM
jody stowitts
Goughary, I can't find this "Sunset" place from whom you ordered yours. Can you help??
Old Mar 30, 2012 | 07:46 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Sunset Porsche = http://www.sunsetimports.com/parts/
No affiliations
Old Mar 30, 2012 | 09:03 PM
jody stowitts
Thanx !!
