964 Forum 1989-1994
Time for Painting & Rebuild Oil System
Old 05-31-2012 | 10:06 PM
  #31
Enso's Avatar
Enso
Default and another from the rear
rear
Old 05-31-2012 | 10:07 PM
  #32
Enso's Avatar
Enso
Default home
home
Old 06-01-2012 | 12:34 AM
  #33
Jacke2c's Avatar
Jacke2c
Formerly turbotwoshoes
Talking Home?
It is where the heart is!
Old 06-01-2012 | 12:52 AM
  #34
touque's Avatar
touque
Looking good Glenn from Saskabush! Now get that thing on the road so you can enjoy the summer! Love the colour btw.
Old 06-03-2012 | 01:03 PM
  #35
Enso's Avatar
Enso
Default More Paint Job Picks
Here are a few more from the paint shop, window frames were painted first then windows put in. also we opted to go with no rubber flange in the front fender to frames, we sealed it off with a body sealer to prevent moister from causing rust again
g
Old 06-03-2012 | 01:06 PM
  #36
Enso's Avatar
Enso
this was not the paint booth BTW
Old 06-03-2012 | 04:07 PM
  #37
Enso's Avatar
Enso
installing the oil system new hoses and thermostat, hoses where a bit of a challenge because of the diameter being a little wider
i purchased all the short hoses but had the long blues hoses built locally with old fittings
g
Old 06-03-2012 | 07:28 PM
  #38
meek's Avatar
meek
Have you used some kind of sealing compound on the thermostat/oil filter/front oil cooler connectors? I think I see some white 'stuff' in your pictures. I am replacing all these hoses and hadn't thought of using any sealer, just replacing the washers. Is a sealant recommended?
Old 06-04-2012 | 01:03 AM
  #39
Enso's Avatar
Enso
yes i used an aircraft thread sealer (white) it's not recommended but i think will help
i also filed the washers to ensure a good fit and used a red gasket sealant here too
good luck
glenn
Old 06-04-2012 | 06:29 AM
  #40
Lemass Automotive's Avatar
Lemass Automotive
Nice idea on the wing sealer, it looks good
One question though what was the reason for fitting the glass before painting the rest of the car?
Other than that it looks spot on
Old 07-21-2012 | 06:14 PM
  #41
Vandit's Avatar
Vandit
Both of the oil cooler fittings on my car are weeping above the hose-side nut. What are my options? Undo and reseal using existing fittings? How? Go the whole new hose route? Also, what size wrenches do I need for these fittings?
Old 08-31-2012 | 02:57 PM
  #42
Enso's Avatar
Enso
Got it all back together around May and have been out having ball ever since
had the threads on the power steering pump come loose that was a quick fix
oil lines are holding good and paint looks good
i'll wait till winter before tackling more projects
glenn
Old 08-31-2012 | 04:39 PM
  #43
Porsche964FP's Avatar
Porsche964FP
Looking sharp!
Old 09-01-2012 | 12:09 PM
  #44
Vandit's Avatar
Vandit
Looking good.
What's the winter plan?
Old 09-02-2012 | 05:27 AM
  #45
Paulie964's Avatar
Paulie964
You make me want to start a project ...
Quick Reply: Time for Painting & Rebuild Oil System
