Gap between top shroud piece and engine shroud
When reinstalling my fan housing/alternator assembly, I reinstalled the piece that mates up to the rear blower and noticed that a small gap exists between this piece and the big shroud under the intake manifold. When the car is running, I can feel a bit of air escaping through here, but not much. I think one of the tabs on the big shroud where it mates to the small might have broken off. Will I be okay running like this?
I had the same issue down where the top shroud mates to the bottom shroud and had to fiddle with it a bit to get it tight. If memory serves the two shrouds have to be tight together first, then the top bolts can be inserted and tightened.
Good luck!
Good luck!
