Do rear Bilstein HD's require bumpstops?
Rear HD’s require an external bump stop on a 964. Just installed a set on mine last week.
http://www.bilstein-shop.com/b16/por...a6f1a2brj23245
There are no bump stops separate from the shocks provided, because they are internal. The dust cover does not have an opening that fits a bump stop. The shocks are painted silver with blue springs
If you installed new OEM spec shocks you installed the Bilstein B6 http://www.bilstein-shop.com/porsche...a6f1a2brj23245
The B6 are not adjustable, the rear shocks come with a dust cover that fits a bump stop and the rears come with bump stops. The shocks are painted yellow and do not come with springs.
So if you installed bump stops on a B16, you did it wrong, however if you installed them on a B6 you are fine.
Hope that helps,
Robin.
With any luck my suspension upgrade will soon be underway.
I'm going with Bilstein HD's and H&R red springs with ride height set at near euro RS.
In searching the archives I am finding conflicting information about the need for rear bumpstops.
The part numbers for the Bilsteins are:
Part Number: 24-017350
Setting: B6 (HD)
Position: Rear
Old Part Number: F4-B46-1735-H2
Quantity Per Vehicle: 2
Part Number: 35-052784
Setting: B6 (HD)
Position: Front Right
Old Part Number: F4-VE3-5278-H3
Quantity Per Vehicle: 1
Part Number: 35-052777
Setting: B6 (HD)
Position: Front Left
Old Part Number: F4-VE3-5277-H3
Will I need to order the OEM RS bumpstops?
Finally, will there be any issues with negative camber at RS ride height?
Thanks!
Jim
Setting: B6 (HD)
Position: Rear
Setting: B6 (HD)
Setting: B6 (HD)
Thanks!
Jim
Note that the thread you resurrected from 2012 was referencing B6 Bilsteins.
Resurrecting this thread as I just bought a B8 kit from Gert. The front struts have bumpstops already on them, but the rears do not. Are the rears internally damped or not? Checking the Bilstein website now...
