Bolt size for A/C compressor plate tensioner
The belt tension adjustment bolt it missing from the A/C compressor plate. What size do I need?
IHI KING!
Its a common 8mm x 1.25 pitch bolt. You can get one at your local hardware store. From memory, I would estimate its about 30 mm in length. You also need a nut to act as a jam nut.
Correction - The bolt is 55mm in length. If you want the official part number is N-040-237-1
