Overheating in 15 minute run session
#31
Ok the update is that I pulled and cleaned the cooler was deff dirty'er then I thought between the fins and installed the replacement piece of the t stat and for the first time actually saw my first real drop in temp when it opened up ! Yay! It had me thrown for a loop as I know I had oil flow to the cooler as I could feel the heat up there and I could watch the temp drop when the fan came on so I must assume it was opening just not all the way. Next track day is march 23rd so will no more then thank you to all for the help...
#32
Congrats! Glad you solved it.
#33
What are the max temps are you seeing during a session now that you replaced the thermostat and cleaned the cooler fins?
I did a Time Trial yesterday and was seeing 10 o'clock on the dial in a 6-8 min session, but never saw it higher than that. The temperature outside was in the 90s Fahrenheit. I'm not sure if that's normal, or still too hot.
