964 Forum 1989-1994
Chunk of piston ring found in engine oil
Old 03-06-2012, 11:35 AM
  #76
FeralComprehension
FeralComprehension's Avatar
*FULL* of win. Buy a freaking lottery ticket already!
Old 03-06-2012, 12:19 PM
  #77
Laker
Laker's Avatar
+964 - glad it worked out!
Old 03-06-2012, 12:49 PM
  #78
Makmov
Makmov's Avatar
That is awesome, glad it wasn't any worse than that.
Old 03-07-2012, 12:50 AM
  #79
Indycam
Indycam's Avatar
Old 03-07-2012, 07:51 AM
  #80
Arrowhead
Arrowhead's Avatar
I was working on my Porsche last night and after my 5th Heineken I found what looked to be a broken piston ring in my front left pocket. Should I be concerned? Could it have found its way from my engine? Maybe I should switch to Coors light.
Old 03-07-2012, 09:09 AM
  #81
Laker
Laker's Avatar
Did it tear through the pocket media? Are you sure it isn't a bottle opener?
Old 03-07-2012, 11:50 AM
  #82
Indycam
Indycam's Avatar
Heineken is not factory approved .
I suggest you get rid of the Heineken asap and refill with any from the Cannstatter Volksfest approved list and try again .
Old 03-08-2012, 02:52 PM
  #83
mshobe
mshobe's Avatar
One last bit (literally): here's that blasted chunk of ring, whose extraction value is now known to be ~$5000:
Much better safe than sorry, of course, but man – this was the most expensive valve adjustment in modern memory.
Old 03-08-2012, 03:13 PM
  #84
Makmov
Makmov's Avatar
put it in a setting and sell it
Old 03-08-2012, 03:27 PM
  #85
mshobe
mshobe's Avatar
Indeed. If I could convince my wife that 17 years is traditionally the "Cast Iron Anniversary," a channel setting would work nicely.
Quick Reply: Chunk of piston ring found in engine oil
