964 Forum 1989-1994
Lack of power above 4,000rpm... NEED HELP !
Old 02-10-2012, 11:53 AM
axl911
axl911's Avatar
Definitely give TPC a call. They were extremely helpful in my install and troubleshooting.
Old 02-10-2012, 01:47 PM
dkcaims
dkcaims's Avatar
Had a call from my mechanic... he is getting things sorted out with their help. Will update when I have more details.
Thanks Tom at TPC !
Old 02-14-2012, 08:46 PM
dkcaims
dkcaims's Avatar
Heard from mechanic today...
Bypassing the TPC black box the problem still remains.
Testing the TDC sensor measures 1.2 volts instead of 3 volts.
Hammer still displaying hall sensor fault code.
Was told it's an electrical issue, not mechanical.
That's it for now...
Old 02-22-2012, 01:38 PM
dkcaims
dkcaims's Avatar
Ok...an update.
Still have not discovered the problem and in fact they said they have never seen this type of problem before and have called a meeting to discuss options this afternoon.
They have been looking into solutions for the past 4 weeks, but have not found one.
They bypassed the supercharger and the problem still persists.
Any ideas?
If this does not get resolved, I'm left with a car that can't exceed 4,000rpm and I may as well have a Hyundai Accent !!!
Perhaps a fresh set of eyes and a confab with my mechanic to discuss what's already been done/looked at.
Old 02-22-2012, 02:28 PM
Makmov
Makmov's Avatar
So we know that it is an electrical probablem for sure?
If so, we know that it's a ignition issue. Right?
The timing is jumping around, the Hall sensor failure, the low voltage on the TDC.
and the AM stuff is bypassed.
The hall sensor tells the DME when No. 1 is firing and is direct to the DME. So if it's not a sensor fult then something else has to be the issue. Curious it also has low voltage at the Top Dead Center sensor. Bad wire, connector, ground or short? There is only a few things left to eliminate in the ignition system. Presuming all the basics have been checked connectors, wires, dist. belt, Hall sensor pick up, high tension wires, and locations, basic ground straps, cap and rotor, what are you left with really. Not getting any knock sensor errors, and presuming those are okay. The DME itself.
Right? Everything points to an ignition issue? More specifically an ignition timing issue.
Any sources of RF interference? Note that RF can be a loose piece of metal vibrating on another peice of metal, it doesn't have to come from a transmitter source.
Old 02-22-2012, 02:39 PM
dkcaims
dkcaims's Avatar
If so, we know that it's a ingnition issue. Right?
The hall sensor tells the DME when No. 1 is firing and is direct to the DME. So if it's not a sensor fault then something else has to be the issue. Curious it also has low voltage at the Top Dead Center sensor. Bad wire, connector, ground or short? There is only a few things left to eliminate in the ignition system. Presuming all the basics have been checked connectors, wires, dist. belt, Hall sensor pick up, high tension wires, and locations, basic ground straps, cap and rotor, what are you left with really. Not getting any knock sensor errors, and presuming those are okay. The DME itself.
Right? Everything points to an ingnition issue? More specifically an ingnition timing issue.
I'll update after the meeting this afternoon and I'll get a complete rundown on what's been done/replaced, what faults the hammer is displaying and any other tidbits of information that might be relevant.
Thanks Makmov
Old 02-22-2012, 02:52 PM
dkcaims
dkcaims's Avatar
Makmov... PM sent
Old 02-22-2012, 08:09 PM
dkcaims
dkcaims's Avatar
OK... here is a printout from the shop detailing their troubleshooting efforts...
Already have 35 hours labor invested into finding a solution to this problem.
Based upon what's been done already...anyone have any additional ideas?
Next step is to install air/fuel mix gauge and boost gauge and hit the dyno.
Anyone know of a good all wheel drive dyno in the Denver area?
Old 02-22-2012, 08:15 PM
Geoffrey
Geoffrey's Avatar
Did you try a different DME?
Old 02-22-2012, 08:28 PM
Makmov
Makmov's Avatar
It does sound more and more like a DME fault. They are pretty reliable, but all bets are off when you add in an After Market box. Obviously there is something wrong with the hall sensor circut being open and they have replaced, they said they check all DME looms and connections. The DME is suspect. Not absolute, but suspect. The DME is also sensitve to RF interference.
And, yeah, there is nothing I am seeing or hearing that would lead me to suspect anything fuel system related at this 10 seconds. It's ignition time, or at least that is the symptoms.
Old 02-22-2012, 08:37 PM
dkcaims
dkcaims's Avatar
When you say DME... do you mean the chip only or the entire box under the seat?
Anyone have a spare working DME laying around? I think the shop is checking with the other shops around town to see if they have one also.
Old 02-22-2012, 10:03 PM
Makmov
Makmov's Avatar
Yes the entire DME the motronic 2.1 box.
Old 02-22-2012, 10:24 PM
dkcaims
dkcaims's Avatar
Anyone have a good source for a rebuilt DME w/ warranty?
I saw them at 911chips.com... Any other suggestions?
Also... there are different revisions of the DME, correct?
Is the 2.1 in "motronic 2.1" the revision number?
Will a DME from a '94 work in a '90? Are they both Motronic 2.1's?
Old 02-22-2012, 10:38 PM
Makmov
Makmov's Avatar
Yeah that is the basic motronic version number, but you need to find it by part no specific. BMW used 2.1 and probably several others.
They changed at some point in the 91 model year.
It might work but I cannot confirm that. Rebuilt is probably the only way to go any more.
Not 100% sure that is the problem but there are some guys out there that can test and repair a DME.
The only problem with a loaner is we don't know if it is a failed DME inside on its own or was it caused by some external source. I know someone that replaced a DME and it ended up just being a DME relay. whoops. Wasn't me though.
Can I borrow your DME you funny guy lol.
Old 02-22-2012, 11:01 PM
dkcaims
dkcaims's Avatar
Replaced the relay a couple months ago...
$525 for a rebuilt unit with 5yr warranty, seems reasonable.
I'm assuming that a hammer cannot fully test a DME like a thorough bench test by 911chips can...?
Quick Reply: Lack of power above 4,000rpm... NEED HELP !
