Presentation and question
Those pics came from google; I think the handle in the first pic is upside down and the lever should point up.
I just takes a weird multi-dimensional twist to get it in there; keep after it!
Did you find your spring?
No way for the spring, both handle are without. I must put the key in the vertical position manually. This evening I will try to reassemble the handle. Yesterday I adjusted the switch, it was a little out of the right position so sometimes rotating the key it didn't activate the switch.
Yesterday evening I reassembled the handle like altarchsa told me and everything seems to be ok but I couldn't re-insert it into the hole in the door. I tried and tried but no way. Now looking to your pics FeralComprehension I can see that your "trigger" (the one in the first photo I posted) is reverse than yours. Mine, if you insert it in the driver's door on the left, is watching to the sky, your seems to be watching to the ground. I tried to change position but it's impossible couse the trigger has a little rounded avoidance that match only if it's watch to the sky. This night I will post some pics, but I can't understand how to introduce it into the door's hole.
Thanks for you replies
Thank you boxsey911, I noticed this problem too. It took me some time to understand which was the right position. I think it is like you say, door unlocked and **** in the right position, also becouse if the door is open and you try to push down the stick, it comes up again.
I did it!!! I could remount it and now everything seems to work properly. I did't find the spring so I have to center the key manually but everything seems to work. Thank to everyone helped me.
Next days I will try to repair my cooling/heating system that doesn't work.
Thank you again
Alberto
Thank you again
Alberto
