964 Forum 1989-1994
OT: Parts washer filtration system
Old 09-17-2012, 02:23 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Originally Posted by Rocket Rob
Ricardo - I installed the filter yesterday on my parts washer. I'm getting a small seep on the lower brass pass through. Did you install a rubber washer, o-ring or use any sealant? I didn't see it mentioned it your original post but thought I would ask. I'm thinking of trying either a rubber washer or some Permatex RTV designed for oils.
Edit: I did some research regular rubber doesn't do well being in constant contact with solvent (naphtha). Viton is recommended. Not sure where I could get that readily today so I decided to try a gasoline resistant gasket sealer. I found Loctite Gasket Sealant #1 at my local auto parts store. I will let it sit over night before refilling the washer with solvent.
No affiliations.
Update - The sealant appears to be working. I had filled the tank with 13 gallons of solvent on Friday night. Sunday night, the joint is still dry. I'm happy.
Quick Reply: OT: Parts washer filtration system
