oil leak by oil tank
My 94 c4 964 has a low oil leak just down the oil tank exactly in the nut you get out for empting the oil tank but is not the oring because the oil cone from above it happens when the oil level is high Any Help???
Probably coming from one of your lines. Clean up the area well and tighten the clamps at the oil lines and see if that helps. If not you'll need to get new oil lines. Not expensive and very easy to replace for the most part.
