Cab wind deflector
Showing where the right side loop would be relative to the seat. I have the cab cover on currently and the wind stop in place.
![](http://i370.photobucket.com/albums/oo147/calguns_photo/rennlist/IMAG0189-resized.jpg)
Left Side loop:
![](http://i370.photobucket.com/albums/oo147/calguns_photo/rennlist/IMAG0187-resized.jpg)
Right Side loop:
![](http://i370.photobucket.com/albums/oo147/calguns_photo/rennlist/IMAG0188-resized.jpg)
Also, make sure you have the following plugs in your car if this was an add-on (as it was with mine)
https://rennlist.com/forums/964-foru...ing-plugs.html
Left Side loop:
Right Side loop:
Many thanks for the pics. As i am away from the car i cannot check for the loops at the back of the seats, though i think they are missing.
I did purchase the plugs and fitted them for the mounting arms.
Also whilst searching on the internet i came across a post where a 964 owner mentions that he does not place the metal bar support of the wind deflector on the seat but instead on the back shelf as it then allows the rear seats to be folded back up.
This is his post:
For me, it was well worth the money because it works. It eliminates the turbulent air whiplash almost completely. It’s mounted with pivotal arms into the carpeted rear panels just to the left and right of the rear seats. Included with the kit are two plastic caps that replace what you now have there, giving a male-female secure fitting at its forward base. On the rear or the base, there are two elastic stretchers that are pulled and fastened to the left and right triangular fittings that serve at the same time for holding the soft top cover in place. With the seats folded down, two metal support brackets fold down from the base and fit up against the carpeted rear section under the rear plastic window. Click the two seats back into place securing the metal support brackets and what you end up with is, one secure wind deflector at no matter what speed, that fits our 964 and will last forever (?).
his link for photos showing the wind deflector mounted with his seats folded up:
http://www.cardomain.com/ride/2449542#24495420028
This is his post:
Interesting..I never thought to try to put the seats back up. I have a feeling the metal is in the same location I have for the seats to secure it into place. I'll test that out and report back tomorrow.
This is his post:
This is his post:
I found the same issue when the seats were down - but I like them down more than up - so I use 2 small bungee cords ( approx 6 inch long) to hold each corner and clip the small bungees to the "D" ring loop that the elastic is clipped to - holds the windscreen in place without any problems.
