RPM gauge stopped working (964)
6th Gear
My RPM gauged has been intermittently cutting out on me. Once it has cut out, turning off the car and back on was the fix.
Now the RPM guage has stopped working completely.
I haven't looked in to it too much, but just wondering if anyone has run in to this or has any ideas.
1991 Carrera 2 auto/triptonic (964)
Thank You,
Jeff
Thank You,
Jeff
Jeff, have you tried doing a search on this forum?
The link below has a few pics of some problem areas to check.
Good luck..
https://rennlist.com/forums/964-foru...h+quit+working
Good luck..
6th Gear
@sschultze09
I did try a search, couldn't find anything.
However I did not come across the forum you suggested, when I searched. So thank you!!
After reading your suggested forum, sounds like most likely my tachometer crapped out on me. And that it might be repairable with some minor electronic components.
Still open to more suggestions....
Thank You!!
Thank You!!
