964 Forum 1989-1994
Bilstein HD rear shock bump stop
Old 02-12-2012, 11:35 PM
  #31
power_up
power_up's Avatar
Originally Posted by 993James993
Hi Power Up,
Thanks for your post. Do you have the part numbers for the RS bump stop and the dust covers?
Thanks!
Part numbers for RS bump stop is 96433310580 require two pcs.
dust cover is 96433310600 require two pcs.
Old 02-13-2012, 12:18 AM
  #32
power_up
power_up's Avatar
Originally Posted by GazC2
That stance looks pretty good to me my HD`s are lying on the bench waiting to be fitted, I put the old 3 layer stops back on, does anyone know the difference in length of the standard ones to the RS ones ? I may still cut them as Thomas has done as they slide all the way down the Bilsteins unlike the boge which retains them at the top of the piston (slight difference in rod diameter)
This is one of those things that bounces round various threads, lets get a decisive answer on this do we need bumpstops on rear Bilstein HD`s and if so what size.
No exact measurement take place. But most people cut the standard one is fine without problem. As I didn't have original one that's why I need to buy new.
Quick Reply: Bilstein HD rear shock bump stop
